Hello all,
I have noticed an issue with the import to workspace function and was curious if anyone else has seen this issue or found a way to resolve it. Basically, when I add an upper level assembly model the collector in the import only collects the necessary part models. I also want it to collect the associated drawings with those files. Has anyone come across this or found a way for the import to grab the linked drawing files without actually going out and selecting those manually?
Thank you,
CC
I don't see a collector preference for initial import to workspace collector in my 10.2. This post also tells the same. Import To Workspace preferences
Thank you,
Binesh Kumar
Barry Wehmiller
