PartRepresentation LoadFromFile Method
pwilliams-3
I am trying to use the PartRepresentation loader in the csvmapfile.txt definition to load a representation to a WTPart. However I cannot get it to load. I always get an exception. Here is the data I'm using.
<nmloader>
<csvpartrepresentation handler="wt.part.LoadPart.createPartRepresentation">
<csvpartnumber>AARONANDPAT</csvpartnumber>
<csvpartversion>A</csvpartversion>
<csvpartiteration>1</csvpartiteration>
<csvrepdirectory>loadFiles\com\steelcase\migration</csvrepdirectory>
<csvrepname>PartRepresentationTestLoad.pdf</csvrepname>
<csvrepdescription>Test Description</csvrepdescription>
<csvrepdefault>1</csvrepdefault>
<csvrepcreatethumbnail>0</csvrepcreatethumbnail>
<csvrepstoreedz>0</csvrepstoreedz>
<csvpartview>Design</csvpartview>
<csvpartvariation1></csvpartvariation1>
<csvpartvariation2></csvpartvariation2>
<csvorganizationname></csvorganizationname>
<csvorganizationid></csvorganizationid>
</csvpartrepresentation>
</nmloader>
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CE7650.7AFD6090]
mschulze
(To:pwilliams-3)
Well I guess it is not of any use anymore for you.
But you can find the solution in CS145533.
You must first add the CachePart loader.
