OData structural properties configuration bug
ChrisB
Windchill version:
Release: 11.1 M020-CPS22
windchill 2.2.2 REST Services
There seems t.b. a bug that makes properties in OData non-filterable when adding a separate configuration for them. Below are the steps to reproduce this issue:
1. We added a random string property to the `Parts` type called `RESTTEST`
   (The property is filterable)
2. We added a custom parts extension configuration as described on p.84 of the Windchill REST
     Services  2.5 User’s Guide having the following content:
Path:
[ROOT]\Windchill_11.1\Windchill\codebase\rest\custom\domain\ProdMgmt\v5\entity\PartsExt.json
Content of config file:
    "extends": "Part",
    "attributes":
            "name": "RESTTEST",
            "internalName": "RESTTEST",
            "type": "String",
            "readOnly": false,
            "nonFilterable": false
As can be seen above, both `readOnly` and `nonFilterable` are set to `false`.
3. After having done this, the property becomes non-filterable, despite the configuration stating otherwise. This can be seen when querying the $metadata of the ProdMgmt domain:
<Annotation Term="Org.OData.Capabilities.V1.FilterRestrictions">
    <Record>
        <PropertyValue Property="NonFilterableProperties">
            <Collection>
                <PropertyPath>VersionID</PropertyPath>
                <PropertyPath>ChangeStatus</PropertyPath>
                <PropertyPath>ShareStatus</PropertyPath>
                <PropertyPath>CheckoutState</PropertyPath>
                <PropertyPath>View</PropertyPath>
                <PropertyPath>RESTTEST</PropertyPath>
                <PropertyPath>CLASSBINDING</PropertyPath>
            </Collection>
        </PropertyValue>
    </Record>
</Annotation>
This seems to be a bug which we haven't found a workaround for, unfortunately. However, we need to add such a mapping for a different porperty to make them writable via the API (since they are attributes stemming from the PartMaster).
Is there a fix for this or some sort of configuration that can circumvent the problem?
Because right now we have the option for attributes from the PartMaster to be
- either searchable
- or writable
but not both.
This is quite a serious issue for us so for ONCE I am asking some PTC folk for an answer, since hardly anyone seems to be able to answer any questions regarding the OData interfaces.
Cheers & thanks a lot in advance
Chris
PS: Why is there no "OData" label for Posts??
HelesicPetr
(To:ChrisB)
what about to separate the domain. One for filtering one for writing ?
So you would have just one config for one domain.
PetrH
ChrisB
(To:HelesicPetr)
Hello Petr,
Thank you for taking the time to answer.
While this might be a possibility, the company I work for currently discourages any further customization of the OData configuration. Furthermore, this could have a negative impact on or existing software that uses the OData API.
Anyway, this doesn't change the fact that adding a property to `PartsExt.json` creates an entry in the `NonFilterable` properties. This smells kind of buggy to me.
Cheers,
Chris
