I'm trying to execute a Windchill report from Thingworx using InvokeIETask with following inputs:
"Task": "ExecuteReportTemplate.xml",
"Params": [{
"Name": "object_ref",
"Value": "OR:wt.query.template.ReportTemplate:1552736"
"Name": "input",
"Value": "startDate=\"2021-04-12\" AND endDate=\"2021-06-22\""
but it results in error:
"error": {
"code": null,
"message": "The timestamp value \"\"2021-04-12\" AND endDate=\"2021-06-22\"\" could not be parsed. The value must be parsed using one of the following Java formats: \"yyyy:MM:dd:HH:mm:ss z\", \"yyyy-MM-dd HH:mm:ss z\", \"yyyy:MM:dd:HH:mm:ss\", \"yyyy-MM-dd HH:mm:ss\", \"MM/dd/yyyy HH:mm:ss\", \"dd/MM/yyyy HH:mm:ss\", \"yyyy/MM/dd HH:mm:ss\", \"M/d/yy, h:mm a\", \"M/d/yy\", \"yyyy-MM-dd\", \"yyyy-MMM-dd\", \"yyyy/MM/dd\", \"yyyy/MMM/dd\", \"yyyy:MM:dd\", \"yyyy:MMM:dd\", \"yyyy,MM,dd\", \"yyyy,MMM,dd\", \"yyyy MM dd\", \"yyyy MMM dd\", \"MM/dd/yyyy\", \"MM-dd-yyyy\", \"MM:dd:yyyy\", \"MM dd yyyy\", \"MMM/dd/yyyy\", \"MMM-dd-yyyy\", \"MMM:dd:yyyy\", \"MMM dd yyyy\", \"dd-MMM-yyyy\" ."
Thanks @rhart for the suggestion, it didn't solve the issue but you pointed me in the right direction.
Here is the format which works:
"Params": [{
"Name": "input",
"Value": "startDate=2021-06-22 14:26:00, endDate=2021-06-22 14:27:00"
Hi @IvanIlicic
The date format is OK I think, but there’s two parameters in the same input.
Perhaps try to use a separate input for each parameter.
"Params": [{
"Name": "input",
Glad I could help 👍
Thanks @d_graham , you explained the problem perfectly.
The format that worked for me is with comma separated parameters but as a single Value (STRING):
"Value": "startDate=2021-06-22, endDate=2021-06-22"
