What policies do you use to govern updating assembly drawings that change due to the modification of an assembly component? Do you make a distinction between fit/form/function changes of components versus cosmetic changes? For instance, a child has a hole that is changed to a slot. The assembly drawing as viewed in CreoView would now not match the component. It still functions the same, but it is not a true representation of the component and could cause confusion in Manufacturing. If a component is potentially used in 1000 assemblies that could be quite a bit of work to check-out, regenerate, save, and check-in all the assembly drawings and assemblies. Also, if that is done, do the assemblies and drawings go through a formal change process?
Wow. That could explode the number of updates our Designers and Engineers will have to make.
