Post WC 9.1 M060 to M070 upgrade issue.
ptc-5052152
I just finished an upgrade from M060 to M070. The PSI completed without incident and all services restarted without error. However, when I try to launch Windchill, after a long delay, I get a Server 500 error (no logon prompt pops up). I did a compare on all .conf files in Apache with the original files from M060 and the were all identical. The error in the Apache error log reads as follows:
[Thu Apr 18 23:16:54 2013] [error] (OS 10061)No connection could be made because the target machine actively refused it. : proxy: AJP: attempt to connect to [::1]:8010 (localhost) failed
We are running on Windows Server 2008 R2 Standard with service pack 1
E:\ptc\Windchill_9.1\Windchill>windchill version
Support Support Installer
Datecode Release Number Release Id Sequence Display Label
M070 9.1 pdml.9.1.70.12 03 Windchill PDMLink
M070 9.1 wsp.9.1.70.12 03 Windchill Service Pack
M070 9.1 vizpviewrun.9.1.70.06 02 ProductView - ProductView Client
M070 9.1 whc.9.1.70.01 03 Windchill Help Center
M060 12.1 vizadapters.12.1.60.23 02 ProductView - Adapters
M070 9.1 ie.9.1.70.12 03 Info*Engine
M110 9.0 vizpview.9.0.110.05 02 ProductView - ProductView Standard
M070 9.1 wlp.9.1.70.12 01 Windchill MultiLanguage Pack
M070 9.1 wnc.9.1.70.12 03 Windchill Services
Temp Patches:
Label Description Install Date
9.1-M060_SUP4 9.1-M060_SUP4 [Seq 02] Aug 31, 2012 9:58:02 PM
9.1-M060_SUP5 Tpatch for wnc.9.1-M060-SecurityTpatch.SUP5 [Seq 10] Sep 1, 2012 12:31:10 PM
9.1-M060_SUP6_1 9.1-M060_SUP6_1 [Seq 01] Sep 1, 2012 12:35:17 PM
9.1-M060_SUP7 9.1-M060_SUP7 [Seq 09] Sep 1, 2012 12:41:57 PM
Non-Default Locale Support:
Code Name
zh_TW
de
E:\ptc\Windchill_9.1\Windchill>java -version
java version "1.6.0_30"
Java(TM) SE Runtime Environment (build 1.6.0_30-b12)
Java HotSpot(TM) 64-Bit Server VM (build 20.5-b03, mixed mode)
Has anyone encountered this issue post upgrade from 9.1 M060 to M070?
> follows:
Sounds like WindchillDS and/or Tomcat are not running.
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
