Pro-E Crashes when using windchill functions
ptc-859099
7-Bedrock
Lately a lot of us at work have had problems with Pro-e crashing when we do simple things in windchill. Like going to event manager, or clicking edit attributes. Anyone else having this problem and know of a solution?
A lot depends on builds you are using. And going back to Intralink, well, there will always be some conservative reflex, even if Windchill outperformes its predecessors.
if your using a Windchill 9.1 you need a Pro/E build code higher than M200
Using Wildfire 3.0 M160 and Windchill 9.0 M020 It seems as if it is an issue because our IT dept "upgraded" us to IE 8 and it isnt compatible with our windchill build code.
