Pro/E settings with Windchill
JeffHoracek
2-Explorer
Are there config.pro settings that should be set a particular way when working with PLM? Currently, when we have an assembly checked out, when we want to check it in, we get prompted to check out all the objects in the assembly, that in turn automatically get checked back in. We've not modified any of these objects, but get prompted to check them out regardless. If we select the "Continue" option rather than checking them out, the workspace then indicates that the objects were modified locally and are now out of sync with the database. I remember some settings that were proesent in WF2 & Windchill 7 that prevented this, but can't remember what they were/are.
We're running WF4 & Windchill 9.1
Any insight would be much appreciated.
Jeff Horacek
Sr. Designer/Global CAD Administrator
STERIS Corporation
5960 Heisley Rd.
Mentor, OH 44060
BenLoosli
(To:JeffHoracek)
Check out the Using Pro/Engineer Wildfire with Windchill guide, chapter 3.
