Hi, I am trying to install Pro/INTRALINK Client r3.4 M062 on a 64-bit PC with Windows & Ultimate. (Note: This same computer used to have 64-bit Vista Ultimate on it and INTRALINK r3.4 M062 Client worked just fine.) The installation goes just fine, but when I try to launch Pro/I I get the PTC window to pop up, but the log-in "window" never comes up. Can anyone give me some guidelines or instruction or tips on getting INTRALINK r3.4 M062 Client to work on a Windows 7 64-bit PC? Thanks!
Hi Mark,
There are two things to be done here:
First, to get the Pro/INTRALINK client to run under Windows 7, you need to change how the embedded java executable runs. The version that comes with Pro/I 3.4 is old and not supported under Windows 7. So if you run it in compatability mode it will work.
Now Pro/INTRALINK 3.4 M062 will run. ![]()
The second step is not required, but more of a "nice to have". If you're running a Windows Theme with Aero effects, when you run Pro/I it will turn them off. To fix this do the following:
start /B %prodir%\%mc%\jre\bin\javaw -Xmx256m -Xss8m -jar %PRO_DIRECTORY%\java\lib\Intralink.jar -l %luknfeel% %intralinkparams% >> "%logfile%"
start /B %prodir%\%mc%\jre\bin\javaw -Xmx256m -Xss8m -Dsun.java2d.noddraw=true -jar %PRO_DIRECTORY%\java\lib\Intralink.jar -l %luknfeel% %intralinkparams% >> "%logfile%"
Note that Pro/I 3.x is not supported on Windows 7 at all by PTC. But this should get you going.
Allan
Hi Mark,
Allan
Thank you for the answer which saved me a great deal of time and frustration
