Problem with my Windchill GUI
VINO
I'm using windchill 10.0 M030.Whenever I tried to revise my part or document the revise popup window appears but that window is keeps on loading.Also in my method server log I'm getting some error but I can't solve this problem.I tried cleaning the cache,cache of the browser and also tried different browsers.Also I have removed my windchill services also.
This is my method server log..
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:07.275 +0000, 172.16.0.25, Moz
illa/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Trident/5.0), http://gt025.globe
matics.com/Windchill/servlet/WindchillAuthGW/wt.enterprise.URLProcessor/generate
Form?Action=ReviseItems&ContainerOid=OR%3Awt.pdmlink.PDMLinkProduct%3A40782&oid=
VR%3Awt.doc.WTDocument%3A96025&selected_oids=OR%3Awt.doc.WTDocument%3A96026&cont
ainerRef=&u8=1&refreshOpener=true, ActiveX component can't create object: 'Scrip
ting.FileSystemObject'
http://gt025.globematics.com/Windchill/servlet/WindchillAuthGW/wt.enterprise.URL
Processor/generateForm?Action=ReviseItems&ContainerOid=OR%3Awt.pdmlink.PDMLinkPr
oduct%3A40782&oid=VR%3Awt.doc.WTDocument%3A96025&selected_oids=OR%3Awt.doc.WTDoc
ument%3A96026&containerRef=&u8=1&refreshOpener=true
73
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:08.407 +0000, 172.16.0.25, Moz
1631
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:07.471 +0000, 172.16.0.25, Moz
328
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:08.584 +0000, 172.16.0.25, Moz
1866
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:07.571 +0000, 172.16.0.25, Moz
831
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:08.736 +0000, 172.16.0.25, Moz
2000
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:07.834 +0000, 172.16.0.25, Moz
897
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:08.804 +0000, 172.16.0.25, Moz
2019
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:08.205 +0000, 172.16.0.25, Moz
928
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:09.148 +0000, 172.16.0.25, Moz
2095
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:09.178 +0000, 172.16.0.25, Moz
2167
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:09.191 +0000, 172.16.0.25, Moz
2208
ERROR : wt.log4javascript.PTC - 2013-05-27 09:31:09.620 +0000, 172.16.0.25, Moz
ainerRef=&u8=1&refreshOpener=true, Unable to get value of the property 'clientHe
ight': object is null or undefined
http://gt025.globematics.com/Windchill/templates/htmlcomp/htmlcomp.js
1816
Someone please help me,.
Thank you
we've got this kind of issue.
Try to set to "false" or "none" all the revise collector preferences.
And collect manually the reference document or dependencies ...
In our case, it was a reference document that the user have no read access rules ... It does not work if preferences are set to "all" , but work if collected manually ...
try the same action as "wcadmin" to know if it is an access rule issue ...
regards
Can you please explain me in steps how to change the revise collector preferences.?I really don't have any Idea about how to set these preferences.Do I need to do something with preference management??
thanks
yes,
Quick links menu on top right / my settings / preferences
In the Tree, Revise / Collector section
Set all the preferences "Inlude xxxx" to None
Gregory PERASSO wrote:
yes,
I have changed all the things to None but still the problem persists and getting the same error.Thanks for help
