Problems when creating a customerized workflow event on an object
XIAOHUCAO
Now ,I want to create a customerized workflow event on an object.
1.】As suggested by PTC,I have to modify the related resource file in this directory firstly:
D:\ptc\Windchill_9.1\Windchill\src\wt\workflow\robotsthe name of the resource file is sychEventResource.rbInfo.
Both the synchEventResource_zh_CN.rbInfo and synchEventResource_zh_TW.rbInfo will have to be modified at the same time.Just like this:
sychEventResource.rbInfo:
synchEventResource_zh_CN.rbInfo:
synchEventResource_zh_TW.rbInfo:
2..】Then I have to modify the following resource files:
The result is:
3.】At last,
resourcebuild wt.workflow.engine.WfCustomEvent true
and
resourcebuild wt.workflow.robots.sychEventResourcen true
Type the following command in windchill shell :
ant –f codebase\makejar.xml
4.】Test
Open the workflow administrator and create ,create a workflow template to test a customerized workflow event on an object:
Without good luck,the event drop-down list can’t be opened in an synchronized robots:
My question is:What’s wrong with the event drop-down list?
0 REPLIES 0
