ProductView worker does not start with Windchill
gchampoux
7-Bedrock
How do I ensure that my ProductView worker starts when Windchill starts?
Each evening, we have a batch file to shut down Windchill (Intralink 9.1 M060) for cold backups. and restart.
In the morning, I always find that the PV worker is not running, and must restart it myself (Site > utils >Worker Agent Admin).
After that, it runs fine.
Can I simply add the worker batch file (created by proe2pv_config.exe, located in the adapter setup folder) to by Windchill restart batch file? Even if that works, are there any caveats?
Gerry
RandyJones
20-Turquoise
(To:gchampoux)
In the "Worker Configuration Wizard - Step 5" screen there is an "AutoStart" checkbox. Check this for automatic restarts.
> Agent Admin).
> Gerry
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
I already had Autostart enabled.
This is why I am puzzled.
And the startup time is set to 15 seconds.
Should I consider changing that value?
Gerry
In Reply to Randy Jones:
RandyJones
20-Turquoise
(To:gchampoux)
I don't believe the cad worker will actually start until there is a job to be published. The worker monitor should start
though.
I have "Startup Time" = 25
AutoStart = checked
AutoErrorStop = not checked
Max Instances = 1
AutoIdleStop = 300
AutoBusyStop = 0
> Gerry
>     > How do I ensure that my ProductView worker starts when Windchill starts?
>     restarts.
>     > Each evening, we have a batch file to shut down Windchill (Intralink 9.1 M060) for cold backups. and restart.
>     > In the morning, I always find that the PV worker is not running, and must restart it myself (Site > utils >Worker
>     > Agent Admin).
>     > After that, it runs fine.
>     > Can I simply add the worker batch file (created by proe2pv_config.exe, located in the adapter setup folder) to by
>     > Windchill restart batch file? Even if that works, are there any caveats?
Randy Jones
1525 E North St
PO Box 5060
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
