I can't believe this has not been a topic on the boards before.I searched but couldn't find anything. Althoughthe document on PTC's site says it was reported in 10.0 M030. Document CS80255. So maybe there hasn't been enough time for people to find it?
We are moving forward this weekend to go from 9.1 to 10.0 M040. We have found many things that, while most are not show-stoppers, are dissappointing changes. They are not huge issues butwhen adding them all up...
Regarding the subject, we are not currently using change manangement. However, providing eveything goes ok with the upgrade we plan to start a project to implement it CM. I am really looking forward to that.In the mean timewe have been creating promotion requests manually.
In 9.1 when we create a promotion request and go through the "wizard" the objects on the Object List pageare automatically marked to be promoted. In 10.0 M040 you have to first select the objects to add to the promotion request (just like before) and then select the check boxon the promotion request of the objects (second time)and pick the iconSet Object for Promotion. They are NOT set to be promoted automatically.
There is an SPR (2144458) on this issue but there is no expected build release to fix it yet. I guess I just wanted to make everyone aware of it. If this topic has already been discussed then please forgive me.
Steve Galayda
I like the fact that there is the option to add items to the promo request in new ways.
Is there EVER a time where you want to collect/add/past objects on a promo req and not want them to be promoted?If so can you explain a use for that? If not, why doesn't WC automatically mark any object that is displayed on the promo req as an object being promoted. Better yet, if this 'option' doesn't offer me anything, I don't even want to see a notification because if it is on the promo request it should be promoted. Period. Plane and simple.
Again, is there is ANY reason that the user would want objects, regardless of the manner of adding (e.g. initially selected,collected, etc), on a promo request but not want them promoted?
Yes, but it isn't very common. I've seen a few companies use the case where they want the promotion package to represent a complete "design package" to simplify the presentation to the reviewer/promoter. In that case some objects in the package may have already been released (think reuse). I've also seen it where items like specification docs that are already released are included in the promotion package of the parts/assy's that are actually being promoted. Essentially, it just minimizes the need to look for the related information.
Russ
In Reply to Lawrence Scheeler:
Is there EVER a time where you want to collect/add/past objects on a promo req and not want them to be promoted?If so can you explain a use for that? If not, why doesn't WC automatically mark any object that is displayed on the promo req as an object being promoted. Better yet, if this 'option' doesn't offer me anything, I don't even want to see a notification because if it is on the promo request it should be promoted. Period. Plane and simple.Again, is there is ANY reason that the user would want objects, regardless of the manner of adding (e.g. initially selected,collected, etc), on a promo request but not want them promoted?
Russ,
That is an interesting use for Promo Reqs. Since this sounds pretty uncommon, I hope PTC changes the default action (and adds a config option for the company/user to set) in order to reduce mistakes and time loss of constanly having to reselect objects.
I look forward to hearing your response for Steve Galayda's question about baseline & promo reqs.
Lawrence
In Reply to Russell Pratt:
Russ
In Reply to Lawrence Scheeler:I like the fact that there is the option to add items to the promo request in new ways.
Can you help me understand why items would need reviewing if they are not changing? Because we currently do not do this, I am not familiar with why this would be desirable but am interested to know more.
