Publish catdrawing with JPG image in PDF
Docserta
We have catdrawing with an JPG image.
The worker generates PDFs without the image.
is there a setting allows you to create PDFs with this image
thank you in advance
Docserta
(To:Docserta)
The solution is as follows:
Add the opion lock.raster.drawing.views.on.publish =yes
in the worker wgmclient.ini file
Hi Docserta,
Few things to Check :
- Make sure Creo Parametric used is 4.0 and above , Refer CS274343
- Set config save_texture_with_model yes
- To isolate the issue from Creo View Adapter to Creo Parametric , try from the Creo parametric Save as PDF and verify the output
Vishwas
Thank you for your attention to my problem.
I was not specific enough in my question.
I'm using a Catia worker in Windchill.
the conversion of Catia files is carried out by Théorem software.
When exporting Drawing Catia files to HPGL and PDF manually with theorem, the images integrated into the plan are displayed.
When posting via Windchill, images are not displayed.
vdegaonkar
(To:Docserta)
I would recommend to raise support ticket with Theorem so that they can look in this issue and may provide quick solution.
Docserta
(To:Docserta)
STEVEG
(To:Docserta)
@Docserta Please mark this post as answered.
