Hello
In the assembly info >> Structure tab it is possible to show the quantity.
When using SW it is possible to exclude from BOM. And here is something weird.
The Structure Tab shows the amount of each part available in the Model.
The Uses mentioned for each instance. if instance is excluded than it shows an additional note. This give (at least some users )confusion.
So here my questions
Hi @jw_CS
I have experience with similar situation with assembly family tables,
Have you check your/user's view of table?
usually user creates own new view but forgets to set the filter with suppressed parts
check the view if the filter is missing or not.
PetrH
Sorry for replaying on my initial question, i can't edit it anymore
I have spoken with the user that has the problem... the problem is a bit more complex.
The user have a few SW assemblies, that are different configurations. in that structure there are some parts / assemblies that are excluded (with or without set as envelope part). dependent on the configuration.
Now there are 3 options:
How does this work, what do i have to do so that quantity follows the quantity that is also on the drawing.
