Query to get history of Change Notice, like Created by, Number,Activity name, Assigned to, Reassigned to,
Hello All,
I am trying to build a report using Query Builder to Fectch history of change Notice like, Name, Activity, Created on, Completed on, Assigned to User,if it is Reassigned, Reassigned User, Vote etc.
Presently i am able to able to fetch details like name, Activity, Created on, Completed on, Assigned to user, if it is Reassigned (Yes or No).
but i am not able to get Reassigned user name, how i will get this.
Here is format of my desired output.
Change Notice NumberCreated onActivity NameRoleAssigned toReassignedReassigned to User
12310/10/14xxxxxxxAssigneeabcyesxyz
12412/10/14yyyyyyyAssigneebobno
Please, guide us to solve this requirement.
Vivek
MarcoTosin
Vivek,
take a look at this article I wrote http://communities.ptc.com/docs/DOC-6348
There is a lot of useful things about reporting with query builder and a section with some report on Change Management.
Hope you can find what you are looking for.
Marco
vuchekar1-VisitorAuthor
Hello Marco Tosin,
I have go through link provided by you.
I am able to fetch some data, not all, Please let us know how i can get this as below,
My Change Notice Page,
I want to fetch data from Task for change process table and process Status table as shown on page.
I am able to fetch the data from "tasks for change process", but not able to find data from "Process Status " table.
Here is report output for above change notice, we will notice that fields from "Process Status " tables are missing in reports.
Please let us know, how i can include this additional data to report.
Here is my qml file,
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE qml SYSTEM "/wt/query/qml/qml.dtd">
<qml>
<statement>
<query>
<select>
<column
alias="Change Notice (wt.change2.WTChangeOrder2)"
heading="Number" propertyName="number" type="java.lang.String">master&gt;number</column>
<column
heading="Name" propertyName="name" type="java.lang.String">master&gt;name</column>
<object
heading="Version" propertyName="versionInfo.identifier.value">
<property name="versionInfo">
<property name="identifier">
<property name="value"/>
</property>
</property>
</object>
<column alias="Work Item" heading="Role"
propertyName="role" type="wt.project.Role">role</column>
<column alias="Wf Assigned Activity"
heading="Wf Assigned Activity Name"
propertyName="name" type="java.lang.String">name</column>
<object alias="Work Item"
heading="Ownership.Owner.Full Name" propertyName="ownership.owner.fullName">
<property name="ownership">
<property name="owner">
<property name="fullName"/>
</property>
</property>
</object>
</select>
<from>
<table alias="Work Item">wt.workflow.work.WorkItem</table>
<table alias="Change Notice (wt.change2.WTChangeOrder2)">wt.change2.WTChangeOrder2</table>
<table alias="Change Task (wt.change2.WTChangeActivity2)">wt.change2.WTChangeActivity2</table>
<table alias="Wf Assigned Activity">wt.workflow.work.WfAssignedActivity</table>
<table alias="Wf Assignment">wt.workflow.work.WfAssignment</table>
</from>
<linkJoin>
<join name="wt.change2.IncludedIn2">
<aliasTarget alias="Change Notice (wt.change2.WTChangeOrder2)"/>
<aliasTarget alias="Change Task (wt.change2.WTChangeActivity2)"/>
</join>
<join name="wt.workflow.work.WorkItemLink">
<aliasTarget alias="Wf Assignment"/>
<aliasTarget alias="Work Item"/>
</join>
<join name="wt.workflow.work.ActivityAssignmentLink">
<aliasTarget alias="Wf Assigned Activity"/>
</join>
</linkJoin>
<referenceJoin>
<join name="primaryBusinessObject">
</join>
</referenceJoin>
</query>
</statement>
</qml>
Vivek
Hi Vivek,
Did Marco's article give you the information you needed to write the query? Let us know if you need further assistance.
