Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
When you have modified a part in your workspace and have it checked out. When you check it back in can you have it automatically cancel your check out?
It will do that by default. You will also have the option of checking the file in and keep it checked out in your workspace or to check it in and remove it from the Workspace altogether.
HIH,
Bob Lohbauer PDM/ PLM Business Administrator Jacobs Vehicle Systems
Well apparently we are having some issues with our testing. When we check in a modified object it is not canceling the checkout. Further it will not cancel a checkout we have to remove it from workspace in order to cancel checkout. Creo1 M30 and Windchill PDMlink 10.0 not sure of buldcode on it.
