Hi Guys,
Whenever we can use save as an option from the library can we set it as a default "re-use" automatically, i found a .frm format automatically excluded. Can we do the same thing?
AJ
to set reused as default on save as :
Navigate to Site > Utilities > Preference Management > Save As
Change the value of Save Selected Objects Only to Yes
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please consider including screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
I would recommend to change ACL rules to disable save as operation on the library items for standard users.
PetrH
Thanks @Fedal it's working as you said.
AJ
