Our test migration was done with autonumbering for EPMDocuments. The OIR for EPMDocuments is also setup for autonumbering. But the filename is used as new number during the upload!! Is this correct? Can this be prevented?
A little more in detail. When I create a new CADdocument in ProE,
- I can change this proposal without limitation
- during the upload, the filename is used as number for the CADdocument!!
