We aregoing to test the ZERO CLIENTS. This is an improvement from the HP and Dell thin clients terminals. The thin client terminals from Dell and HP physically connects to a singe physical local server/workstation. The thin clients terminals are 1:1 ratio between terminals and local servers/workstations. Since ProE only uses 1 CPU core,it is a waste if you have multiple cores per CPU socket in your server. With Zero Client technology, we are going to attempt to connect to VM Desktops, thus efficiently utilizing the server with multiple cores.
There are some companies that currently offer it:
We have offices in India and UK which are having latency issues and the data has to be secure in our systems and cannot be exported out. For ProE licenses we also have license server locally placed, borrowed or on their mobile system when users travel. For permenant remote users, we usually place a local license server at that remote office.
Patrick
the great number one pro with Zero Client and Thin Client terminalsare that even if you have a complete cut of connection, you data and session in the server room is still running and you will not lose work. You completely remove the need and the equation of file or cache compression, because there is no file transfer.
