Rename collector like save as collector
ghansen
Hi all.
I have at WTpart structure. In Windchill I now want to rename all members of a WTpart assembly. I go to the structure of the WTpart assembly and was hoping to be able to collect the WTparts below. And rename using naming patterns. But I don't get to collect the WTparts below at all.
If I chose save as instead of rename I can collect and rename all using naming patterns.
I have looked into Preferences, but I cannot see what is wrong?
Best Regards
Gunnar
ghansen
(To:ghansen)
Forgot to say we use WC Release: 10.2 M030-CPS23
BenPerry
(To:ghansen)
Do you have a CAD file associated to the WTPart?  If yes, then try to initiate the rename from there.  That will give you a different rename UI screen.  And then perhaps from there you'll be able to collect in dependents if they're not already there.
ghansen
(To:BenPerry)
No, there is no cad part related
