All,
Is anyone familiar with the api calls required to rename the file name of an EPMDocument? I am working on a tool to rename the file name of a list of EPMDocuments, and I am using the PTC call wt.epm.EPMDocumentHelper.service.changeCADName(keymap). After running the tool the file name is updated in the browser, but it will no longer be found by Pro/Engineer. Is there another call that I should be using or do I need to update the content too?
Thank You,
Paul Hartwig
