Hi Everyone,
I have 100 components in a single assembly, I want to rename all the components like number, name & filename. Can we use the export from the spreadsheet for this? Actually, I tried to change the filename on this method, but I can't change the name & number. Can you help me with how we can do this?
No, the function for multi CADDocument creation does not exists as for WTPart.
PetrH
This is standard OOTB functionality. If you rename a CAD assembly, you can use the collector to get its dependent models and rename, renumber or change filenames of them all in one shot.
Hi Mr. Avill,
Thanks for the replay.
I import all the details using the import from spreadsheet method, there I can change the filename(Common name), I want to do the same thing for numbers and names. I tested on here if I change the name or number in WT Part it's created with a new number, not updating the latest modified.
Amir
The spreadsheet does not support changing the numbers. Number is unique identification and the spreadsheet do not allow you to define old and new one.
PetrH
Agree with @HelesicPetr , export/import is not the right method unless you are trying to make new items, not rename/renumber existing items. I am bit confused on your steps. I am familiar with Export of Importable Sheet with WTParts but not for CAD. Can you explain your steps and process with screen shots perhaps?
Apologize for the delay in response. (reply is not update)
S1: Using the import the spreadsheet to create a WT Part, once i create a WT Parts i can able to change the name. but i can't able to change the number. I attached the file below.
WCTYPE|wt.part.WTPart|com.ptc.MechanicalPart this type which i used for WT Parts.
I want the same thing for EPM document and as well i want edit it's new only i am not association each other.
When i create a WT Part automatically create a same number name in EPM document it's possible. Please find the screenshot new_multiple_parts there is there any way to create EPM.
