Replicate SQL Database & Windchill Directory Server from Production to Test Environment
MA_10143395
2-Explorer
I need to replicate SQL Database & Windchill Directory Server from Production to Test Environment
7 REPLIES 7
BenLoosli
(To:MA_10143395)
Read the Rehost guide for your version of Windchill. It is not for the faint of heart!
The most convoluted document PTC has created to date :-P.  It doesn't help that the scenarios they include don't even discuss deployments that are using the new model (no supplied java, no WC DS etc)
HelesicPetr
(To:jbailey)
Hi @jbailey,
The documents are good for general knowledge.
If you've never done a clone of the system you should start with general knowledge documentation to understand what have to be done ,
So I would start with the rehost guide
Windchill rehosting is very complex operation and you could do many many mistakes.
PS> not you but anyone 😄
PetrH
avillanueva
23-Emerald I
(To:jbailey)
Agreed, I think they tried to cover too much. Your install could be anything from a monolithic install to a multinational, clustered installation, Windows and linux. That's tough to capture in a single guide or tool. I would suggest folks take that information and write their own guide which matches their installation. I've struggled using that as I never could determine what to ignore and what was important. Get that configuration file right or you've hosed the system. I wish it was more transparent in what it was changing. Perhaps having a practice mode where it told you what it was doing without actually changing files would be helpful.
BenLoosli
(To:jbailey)
Mike Lockwood has offered anyone who can use the Rehost Guide alone and do a successful rehost a full lobster dinner. He made this offer about 5 years ago, or more, so far he has had no takers.
RandyJones
20-Turquoise
(To:BenLoosli)
If I remember correctly the offer was to any PTC employee who could do this.
Not sure of what version but this should cover all bases:
https://www.ptc.com/en/support/article/CS162685?source=search
