Report of documents shared into a Project using Report Manager
WajidHussain
6-Contributor
How do I build a report of all the documents shared into Project?
Here are the columns I am intersted in :
Document Number, Document Name, Version, Project Name, Folder Location
I know i need the Project2 and Document object, but I am not sure what other table/object and fields i need to link together.
Any help you can provide will be much appreciated!
I am using Windchill 9.1
Anand
(To:WajidHussain)
Hello Wajid,
Please use the Article CS209852 for your reference
Athmanand
Anand
(To:WajidHussain)
Hello Wajid,
Athmanand
After I load the QML in Windchill, it fails to work; no results are displayed, regardless of which search criteria I use—or even if I perform a search without any criteria. the windchill version is 12.0.
I suggest you leave a comment on the article from which you downloaded the report, asking for clarification on how the report works.
That report probably performs searches that are NOT what you are expecting, so it is worth asking for clarification.
Marco
thanks, it's a good suggestion, I've raised my concerns on that article.
