Report on WTDocument File
klozier
11-Garnet
I am trying to create a report of WTDocuments with files attached as the primary content.  I don't seem to be finding the field.  With EPMDocuments there is a field called filename.  Has anyone been able to generate a report of WTDocuments and the primary contents file?
BineshKumar1
(To:klozier)
Tables: WTDocument, Application Data
Join: WTDocument = Holder to Content = Application Data
Columns: WtDocument >> Name, Number,
              ApplicationData >>  filename
Thank You
Binesh Kumar
6 REPLIES 6
Kelly,
I think you opened this discussion in the wrong place (under Creo section).
Ryan Kelley‌ can move it for you in Windchill section or maybe in reporting group.
Marco
Thanks for spotting this and notifying me Marco Tosin‌. I've moved this discussion into our PTC Windchill‌ product community.
BineshKumar1
(To:klozier)
Thank You
Binesh Kumar
Binesh,
could you please add a line to Resource for reporting pointing to this discussion?
Thanks.
Marco
Marco
done, Sorry Marco, for not replying earlier
klozier
11-Garnet
(To:klozier)
Thank you
