Hi Guys,
I want to delete the bulk old representation. How we can delete it in Windchill?
Amir
Are you asking how to delete in bulk old representations? For non-current iterations? There are some add ins you might need.
https://www.ptc.com/en/support/article/CS211115?source=search
Clarify question if this is not what you were looking for.
Thanks for sharing @avillanueva
Can we use this same step to delete the default representation in only one iteration?
Amir
FYI:
Another option is to use PTC's command line utility.
https://www.ptc.com/en/support/article/CS62748
It isn't as popular because
But, if this is a one-time cleanup and really just an administrative task, the command line solution will do the job without injecting that customization into Windchill.
A third option comes from INNEO's GENIUS TOOLS for Windchill.
The Genius Tools Publishing Bundle is mentioned on page 3 of their brochure.
It is designed to clean up obsolete visualizations and free up file vaults disk space via automated background maintenance tasks.
Thanks for the reply @mmeadows-3 @avillanueva
How and where we can get the OID https://www.ptc.com/en/support/article/CS62748
Amir
If you mean the OID of the container, I recommend using the CONT_PATH option which is simpler. To get the OID of the representation, I recommend using a QueryBuilder report to get a list and report out its OID. Then that file can be including in this command.
Which part? Knowledge base has lots of examples of reports that you can mod for your needs:
https://www.ptc.com/en/support/article/CS377342?source=search
