Representations/Annotations Help
WT_10157238
6-Contributor
Can anyone tell me how to get these options to show up in Representations/Annotations under Details? Our only option on the dropdown is System Default.
What you showed in @TomU 's image was a right click on the published drawing. On the toolbar above should be an icon to create a new representation. I have the same as you in that drop down. Right click on a published representation and you should see the same thing as Tom.
Thanks so much, no dropdown, but I do see the pdf I was looking for under "Files"
