Resetting Team template for Primary Business Object ???
DPK
There is a critical situation with my organization that I have a workflow which is being triggered from the library and I want to resolve the roles in the workflow activities from a team template which is created at Product context level.
Is it possible using some codes or something ??
Participation of the community members will be appreciated.
LoriSood
23-Emerald I
(To:DPK)
This article may get you started. It lists the APIs used to get the team template and then the roles from that template:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS197190
DPK
(To:LoriSood)
Thank you Lori, actually we skipped this step for a while but started development again on the same.
Thanks again for your concern on the same.
