Restore wt.lifecycle.StateRB fole
BrianToussaint
I messed up with my StateRB file.  How do I restore it to the previous version from backup?  I tried to copy the files there and run the ant command but it didn't take them.
@BenLoosli PTC support finally came back with that I need to go to the wtCustom folder to grab the latest files.  Then I had to rebuild them through a force compile and then I could run the ant command.
Lesson learned, do not use the Replace as a Filter button. 😂
5 REPLIES 5
Try using enumCustomize and edit the StateRB.RB.ser file in codebase\wt\lifecycle folder.
How many customized lifecycle states do you have? I only have 1 so that is easy.
I lost all the OOTB lifecycle states. It will not let me add them back in, so that is why I need to restore to a previous version of the file.
Never hit the "Replacement" button and then do a save without unchecking it. I was trying to narrow down my test server so I made sure I duplicated it on production.
Have you tried copying the file from another machine and then running the enumCustomize and ant -f MakeJar.xml command?
I did try. But when I ran enumcustomize, it remembered the "Replacement" and didn't have the other states. I also tried to run the ant before enumcustomize and nothing. I am thinking something is set in a table?
