Retrieve version of part/model from Windchill api?
SD_9870778
Hi everybody, do its possible to retrieve version of a specific part/model from the Windchill api?
Or it is only possible via the Creo api??
Thank you.
avillanueva
(To:SD_9870778)
affectedVersion=aPart.getVersionIdentifier().getValue();
avillanueva
(To:SD_9870778)
SD_9870778
(To:avillanueva)
Great Thank you!
Is this a method  from the Rest API? Is there a document where I find more method like this one?
Thank you
SD_9870778
(To:SD_9870778)
Probably the Java API. not Rest 🙂
Hi @SD_9870778
Public Java API documentation is here cs17101
PetrH
SD_9870778
(To:HelesicPetr)
Perfect Thank you!
