I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS20
We have FileBased series in system called wt.series.HarvardSeries.BDKBased.
When we revise the series from 1D.1 our expectation is to it goes to 0 as per the series configured.
We are getting the error message "For input string: "A"
objects which are in 2D.* are able to revise to 0
I am attaching the wt.properties as well as series.xml file for more clarification
Here are the errors that I faced
I think something got messed up in your message or files were stripped. You only need to post the configuration of your series but if Filebased, the text would be fine.
