All,
i would like to get your advice on the following issue we got into.
as part of our promotion process we produce wtdocs automaticaly and "attahed" then to the coresponding wtpart, using "wt.part.LoadPart.createPartDocDescribes".
now, when a user revises a part using theReviseaction, the new version of the part always carries forward the link to the document.
is there an option to set the system not to do so ?
Rami
Hi Rami
there are two ways to link wtdoc. One is for the reference documents (this is a wtdoc subtype) and the other as described by.
They used to behave differently up to PDMLink 8. Then in 9.0 they added flexibility where both can be revised but one will remain at the version it was attached to, while the other type will be carried over.
I can't recall which one. I think it is the reference document which is carried over.
I would check which type of wtdoc you actually create and check which type you should be using.
