The scenario is this. I checkout an obeject/file but I didn't do anything, after that I checkin the object/file and the version is added.
can somebody expalin to me why the version added if I didnt modify anything?. It makes me confused. ![]()
Thanks in advanced!
Hi, everytime you check out and check in an object in Windchill a new iteration will automatically be created, even if you havent changed anything.
If you do not want to create a new inetration you should have used the "undo checkout" instead of "check in"
Thank you! now I know what were going to do. ![]()
Hi
Everytime when I click Revise & checkout in PROE New Version of CAD Drawing added to Windchill, When I click CheckIn , new iteration created of Revised CAD Drawing. So At the end two iteration created. Anybody knows why two iteration created while Revise CAD Drawing?
As I know when you revise new version created.
Ex.
I have -1 version
when you click revise it will become A.1
if your going to check out/checkin the new version is A.2
