SQL Database access and location
Weber
When installing WPPT a new SQL database named ##MSEE## or similar is created. This database is located in the C-drive of the server where WPPT is installed. I dont want this cause of disk space. Futher I might have an existing SQL installation that I want to use. Now to my question: How can I determine the loaction, name and access of the SQl database used by WPPT ? I could not find a option for this when installing WPPT, when I moved the SQL after installing I couldn't connect the ProE clients. Also I had no acess to the SQL databases using SQL managment studio.
ptc-2211192
2-Explorer
(To:Weber)
you can not just move the databse files. you must detach the database. Move the files. Then reattach the database. Here are the Instructions http://support.microsoft.com/kb/224071
Hallo Keith thnak you but this link does not work.. Now how can I USE a database when installing WPPT ? Is this right that WPPT install SQL Express if no other SQL Server is installed ?
ptc-2211192
2-Explorer
(To:Weber)
I Am not sure why the link does not work. I tested it and it is fine. If you do not have sql installed it will use sql express for the content datbase and windows database for the share point side.
