SQL custom meta
Darquise
SQL custom meta
In what SQL table is the custom meta stored. For example, we have custom Objects types & attributes. I'd like to query the SQL database but I don't know in what table this information is stored? Any ideas?
1 ACCEPTED SOLUTION
Yes, So if these are global attributes, they would be located under following tables:
If they are string type attributes:
StringDefinition and StringValue
Boolean:
BooleanDefinition and BooleanValue
Timestamp
Timestampdefinition and Timestampvalue
Integer
IntegerDefinition and IntegerValue
Definition tables will have attribute name details whereas StringValue will have the value, the connection to EPMDocument will be in StringValue table, A sample query is as follows:
select C.Documentnumber EPMDocNUMBER, A.value2 "attributevalue" from StringValue A,StringDefinition A1, EPMDocument B,EPMDocumentMaster C
where A.ida3a4(+)=B.ida2a2 and B.ida3masterreference=C.ida2a2 and A.ida3a6=A1.ida2a2 and A1.name='attributename'
and B.latestiterationinfo=1;
7 REPLIES 7
hello,
you mean you created IBAs and Soft Types or you created Custom Hard Model types?
it would the 'more attributes' tab in the document information (we renamed to say Metadata)
(see attached screen shot from windchill document i )
which sql table stores this information?
in Type & Attributes, I created sub-types under EPMDocument. I then created custom attributes which i added to my subtype. Does that make sense?
Boolean:
Timestamp
Integer
Getting close! Thank you 🙂
I'm getting an error at:
A.idA3A4(+) = B.idA2A2
Incorrect syntax near ')'
ohh, that's for Oracle right. In SQL, it would be something like this:
from StringValue A right outer join EPMDocument B on A.idA3A4 = B.idA2A2
Yes sorry i assumed Oracle.
