Save-as carries viewable
ealdrich
When we do a save-as on a drawing/part it carries over the viewable with it. We want to disable this so the new drawing/part doesn't have a viewable until it is modified (checked out/in). Is this possible with a config change? I'm not finding anything concrete in the KB.
TomU
(To:ealdrich)
Take a look at the wvs.properties file. Specifically these properties:
"publish.copymarkupsforward"
"publish.copyrepresentationsforward"
"publish.copyforwardallrepresentationsonrevise"
"publish.copyforwardallrepresentationsoncopy"
"publish.documents.copyrepresentationsforward"
"publish.documents.copymarkupsforward"
"publish.copyforwardallrepresentationsoncontainerchange"
TomU
(To:TomU)
By the way, these are set using the xconfmanager utility. Documentation on these properties is available in the properties.html file located in <windchill root>/codebase folder.
ealdrich
(To:TomU)
Thanks! I'll look into those. I have the Windchill Visualization Services guide on PDF so I'll look into the descriptions. PTC CS recommended I modify the following values to "true":
1. publish.service.readytopublish.enabled to true
2. publish.republishonepmdocumentchange to true
3. publish.publishonepmdocumentchange to true
TomU
(To:ealdrich)
I set most of the properties I listed to false. When I revise an object to make changes, I don't want the old representation to come along, nor do I want a new representation of the revised object to be created (since the changes haven't been created or checked in yet.) I wish the revise action wouldn't create an extra iteration separate from the first check-in at that new revision level.
