SearchCondition not working in Windchill 10.0
jfelkins
Hello
I am using Windchill 10.0 and found that the SearchCondition(EPMDocument.class, EPMDocument.Number,SearchCondition.Like, "123") is not resolveing in my code. It worked in 9.1 but now I am having trouble. I am using Eclipse and the same library paths as 9.1 but in 10.0.
My error is: "The type com.ptc.windchill.annotations.metadata.Serialization cannot be resolved. It is indirectly referenced from required .class files."
So does anyone see the same issue as me? And how to resolve it? I can remove the last string agurment and it seems to resolve but using the constuctor with a sting at the end seems to have problems.
Thanks for your help!
hi,
is Windchill Information Modeler installed and srclib/tool/*jar in your build path?
hth, martin
jfelkins
(To:jfelkins)
Thank you Martin
I did not have the srclib/tool/*jar in my path and it fixed the issue.It is interesting that I did not need that path in 9.1 but I do in 10.0. Do you know why?
In Reply to martin kraegeloh:
hi,
hth, martin
It is WT_HOME%\srclib\tool\Annotations.jar that was not in WC9.1.
Thanks and Regards,
Peter (Yoon) Kim
281-483-0629
CONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of Hamilton Sundstrand Corporation and its affiliated companies. If you are not the intended recipient, please 1) do not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return e-mail, and 3) delete all copies (including all attachments) from your computer. Your cooperation is greatly appreciated.
