Hello
is there a way in PDMLink to pull out the overall access permissions of each users, user groups etc. ?
I cannot find any tool from the site utilities page.
Is it something companies have to develop themself or buy a third party software ?
Thank you
NacNac
Hello NacNac,
You can find the definitions of these inAccessPermissionRB.rbInfo file. You will find it in <wt_home>/src/wt/access.
Hello
many thanks !!!
-1.value=Full Control (All)
0.value=Read
1.value=Modify
2.value=Create
5.value=Delete
6.value=Administrative
7.value=Revise
8.value=New View Version
9.value=Change Permissions
10.value=Download
11.value=Modify Content
12.value=Change Domain
13.value=Create By Move
14.value=Change Context
15.value=Set State
16.value=Modify Identity
One route to obtain an ACL Report is to run WINDU, with I think Domain Policy option only.
another is command line:
windchill wt.tools.support.ACLReport <output_file>
per ptc page: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS116472
I havent tried the 2nd route & if it works well, it would like be easier than the WINDU method.
Larry Jett
Hey Bert,
One of my sites is reporting Creo 3.0 slow startup issues when using a VPN, did you work out what was causing this?
Gary
