Send to PDM causing error ATTENTION: Values associated with incorrect object
ndele
9-Granite
I am using Windchill ProjectLink Release 13.0 and Datecode with CPS 13.0.2.0
Using the action "Send to PDM" is resulting in an error: "ATTENTION: Values associated with incorrect object." The objects are .PRT / .ASM / .DRW files.
They were created within the Project. We are now trying to send it to PDM. Tested to see if it was a permissions issue using an admin account, but same error occurs. I do not believe the objects are deprecated or abandoned - they have only been inside of that one Project. Much appreciation to any insight what the issue could be.
TDT
(To:ndele)
Hi @ndele,
Have you reviewed the MS logs for any errors or related information?
