2023-08-18 11:01:31,859 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - 554 5.2.252 SendAsDenied; windchill@XYZ.com not allowed to send as User1@xyz.com; STOREDRV.Submission.Exception:SendAsDeniedException.MapiExceptionSendAsDenied; Failed to process message due to a permanent exception with message [BeginDiagnosticData]Cannot submit message. 0.35250:452D0000, 1.36674:01000000, 1.61250:00000000, 1.45378:02000000, 1.44866:00000000, 1.36674:7A000000, 1.61250:00000000, 1.45378:05000000, 1.44866:00140000, 1.36674:0A000000, 1.61250:00000000, 1.45378:16000000, 1.44866:8B250000, 1.36674:0E000000, 1.61250:00000000, 1.45378:A4250000, 1.44866:12020000, 16.55847:DB130000, 17.43559:0000000030020000000000000000000000000000, 20.52176:140F2B9A120070201F000130, 20.50032:140F2B9A8217101012000000, 0.53414:0201E265, 0.35180:0A00070E, 255.23226:21000000, 255.27962:7A000000, 255.27962:0A000000, 255.27962:0E000000, 255.31418:03000136, 0.35250:03001700, 1.36674:0A000000, 1.61250:00000000, 1.45378:02000000, 1.44866:A8000000, 1.36674:32000000, 1.61250:00000000, 1.45378:AD000000, 1.44866:01000000, 16.55847:23010000, 17.43559:00000000F0030000000000000000000000000000, 20.52176:140F2B9A120070200A001380, 20.50032:140F2B9A8217101073000000, 0.53414:03000B67, 0.35180:0A004200, 255.23226:78000000, 255.27962:0A000000, 255.27962:32000000, 255.17082:DC040000, 0.27745:0A004366, 4.21921:DC040000, 255.27962:FA000000, 255.1494:1F000430, 0.38698:05000780, 1.41134:46000000, 0.37692:86000000, 0.44092:86000000, 0.41232:6A000100, 0.60208:6A000100, 0.37136:86000000, 0.34608:86000000, 0.55056:86000000, 0.42768:86000000, 0.56112:6A000100, 0.52807:6A000100, 1.41134:46000000, 7.36354:01000000000001096A000100, 4.33016:DC040000, 7.40748:010000000000010B6A000100, 7.57132:0000000000000000AFB80300, 4.39640:DC040000, 1.63016:32000000, 8.45434:EBB59C541EF5C248B9DC8C7CEFCF996086000000, 1.46798:04000000, 5.10786:0000000031352E32302E363639392E3031383A534A30505231394D42383135373A65306637386435312D326532372D343961372D383234392D6436336665313935613639303A36363832343A2E4E455420362E302E32300000000000, 7.51330:B9CFD56304A0DB0800000000, 0.39570:00000000, 1.55954:0A000000, 1.33010:0A000000, 2.54258:00000000, 0.40002:00000000, 1.56562:00000000, 1.33010:0A000000, 2.54258:00000000, 0.40002:00000000, 1.56562:00000000, 1.64146:32000000, 1.33010:32000000, 2.54258:DC040000, 1.33010:32000000, 2.54258:DC040000, 255.1750:DC000000, 255.31418:0B00F410, 0.22753:40000730, 255.21817:DC040000, 0.64418:0A001580, 4.39842:DC040000, 0.41586:E7000000, 4.60547:DC040000, 0.21966:02011330, 4.30158:DC040000[EndDiagnosticData] [Hostname=SJ0PR19MB8157.namprd19.prod.outlook.com]
https://www.ptc.com/en/support/article/CS389508?source=search
Check link above out. Windchill will often send emails as another user which your email server is rejecting.
