Server_Prefs.xml
GregOlson
Server_Prefs.xml
Having issues with downloading the server_prefs.xml file from the Visualization Configuration Administration UI.  Does anyone know where on the server this file is located...I'll just go get it manually via Windows Explorer.
Greg
LoriSood
23-Emerald I
(To:GregOlson)
It looks like this data is vaulted. Each file associated with a WVSConfigurationTemplate object in the database and is stored as an ApplicationData object.
What happens when you try to manually download the file from the Visualization Configuration Administration?
Nitin
7-Bedrock
(To:GregOlson)
Yes, for sure this is vaulted.
I would check MS logs while trying to download the xml. In case the file is not present in the vaults or if there are some problems with vault configuration (not mounted, valid..), there will be error something like wt.fv.master  - Error in doDirectDownload.
Hope this helps.
-Nitin
The configuration templates are vaulted when you have usevaultsforallcontent set to true, if not it will be stream data. You can query the db using the below query to get the location of the configuration files. There were some issues with downloading server prefs when the preferred file server is set to a replication site in pre 10.1 M040 release.
select
distinct wvc.CONFIGURATIONTYPE,ad.filename FILENAME,
fvm.path ||'\'|| to_char(fi.uniquesequencenumber, '0000000000000x') LOCATION,
round(ad.filesize/1024) FILESIZE
from
applicationdata aD,
WVSCONFIGURATIONTEMPLATE wvc,
holdertocontent htc,
fvitem fi,
fvmount fvm,
Fvfolder ff,
fvvault fv
where
ad.ida3a5 = fi.ida2a2 AND
fi.ida3a4 = ff.ida2a2 AND
ff.ida3a5 = fv.ida2a2 AND
fvm.ida3a5 = ff.ida2a2 AND
htc.ida3b5 = ad.ida2a2 AND
htc.IDA3A5=wvc.IDA2A2;
Thank you,
Binesh Kumar
Barry Wehmiller
giulix
(To:BineshKumar1)
Lotsa thanks for that query, dude. I've been looking for the place where those files are stored for years.
