Hi all,
in windchill, how can I set up the columns width?
I can set, for each windows (checkin, checkout, workspace, ecc...) which columns I want to see, but I can't set their width.
In the picture attached, for example, I can't set how large must be the column named "posizione" (position folder in server).
Thanks.
This is not currently possible.
Also, if you have maintenance and can view product ideas, there are two dealing with this exact issue.
http://communities.ptc.com/ideas/4696
http://communities.ptc.com/ideas/1703
Vote them up!
