Setting the default values for the OOTB WTPart attributes
dwilliams
Hi Gurus,
Can you tell me how I can set the default values for the OOTB WTPart attributes (Standard or Configurable, Create as End Item, Assembly Mode, etc.)? I thought this could be done with an OIR or by setting the default value in the resource bundles but it doesn't seem to be working. Any help you can provide will be greatly appreciated.
Windchill 9.1 M070
Best Regards,
Dax Williams
Engineering E-Tools Administrator
GE Healthcare OEC
Surgery
-<">mailto:->
384 Wright Brothers Drive
Salt Lake City, Utah 84116
Dax, You can set them in oir with custom classes and upating through configurable rules xconf file. I have previously posted path to the file. I'm replying on my phone so let me know if you can't find it or no one else points out after this. I'll locate it.
Sent from my Verizon Wireless 4G LTE Smartphone
Did you find how to do this? We also want to change something.
We want to add a new value to the "legal value list" of the attribute "assembly mode".
Is this possible and how can we do this?
thanks in advance
kind regards
Ruben
KD
(To:rvanveerdeghem)
Hi Ruben,
Use enumcustomize tool to add / remove any entry from the legal value list of the attribute of "Assembly Mode".
Thanks and Regards,
Kaushik
Hi Kaushik,
Thanks for your awnser and sorry for my late one :-).
I'll give it a try.
