I'm looking for a possibility to store the output which is generated from publishing. For example I can publish a WTPart to an IGES and STEP. We want to store the generated STEP in folder /Default/STEP and the IGES in /Default/IGES.
For <post-publish> there is the option "folder". But this always generate a PVZ and is also not working for multi-output. Is there any option like this we can use in the <additional-files> section or is there any other possibility to do this?
Thanks1
