Traffic Light Attribute Implementation
CC_10081426
6-Contributor
Hello everybody,
I have a very short question about generating a new attribute including a traffic light. I have created a new integer attribute with the following formula behind:
(state.state == “CANCELLED”) ? 0 : (state.state == “INWORK”) ? 1 : (state.state == “RELEASED”) ? 2 : 3
But when I try to save the changes I get the following warning: "Value entered for Formula is invalid."
What am I doing wrong here?
Many thanks!
8 REPLIES 8
((state.state == “CANCELLED”) ? 0 : ((state.state == “INWORK”) ? 1 : ((state.state == “RELEASED”) ? 2 : 3 )))
CC_10081426
6-Contributor
(To:rhart)
Still not working ...
I guess the == operator can't compare two strings then.
Perhaps try a Business Algorithm to compare them.
for example, this is how it works:
state.state=="INWORK"?1:((((state.state=="20_TS_NOT_VALID")?0:(state.state=="10_TS_FAST_TRACK")?1:(state.state=="RELEASED")?2:3)))
Thanks for your solution. It is working well... But I have another question related to this topic. Is there a way to have more than these three colors? For example an additional black color for obsolete documents? And another question ... is it possible to show the traffic lights in the documents table?
Thanks in advance!
The question of more colors in the traffic light, I haven't looked into it further, but it should be possible.
https://support.ptc.com/help/windchill/r12.1.2.0/de/index.html#page/Windchill_Help_Center/customization/WCCG_UICust_PresentInfo_CustomGrapicalAttributes_procedure.html#
Thank you very much but I think this will be to complex.
Related to the new Attribute trafficlight ... Is there a way to hide the title of the attribute in the table like "General Status"?
avillena
(To:CC_10081426)
Hi, I know it's been a while since you opened this thread, but I had the exact same issue, and I have recently discovered what the problem was!
If you want to create a "traffic ligh" attribute the normal thing is to go to the WIndchill Help, and copy the example code:
The problem is that the quotation marks of this example code are the reason why you get the message "Value entered in Formula is invalid", although the code is correct!!
I have realised that the quotation marks copied from Windchill Help are different from the quotation marks that you type, and this is the reason of the error!
So just change the quotation marks and the value entered in the formula will work!!!
