We understood that the translation vector(positional shift) and rotation vector(orientation) is relative to its immediate parent assembly.
However, we want to understand the attributes in CADBOM or columns in epmmemberlink table that represent the transformation values with respect to top-level assembly. In Teamcenter, this is represented by Absolute Transformation Matrix.
Absolute Transformation Matrix Definiton : It represents the transformation from the component's local coordinate system to the global coordinate system of the top-level assembly. This matrix determines where the component is located in 3D space within the overall structure.
Thanks in advance
Hi @NP_10570407
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
