Unable To Connect To Windchill 12.1 : Service Unavailable
Divyanshi
7-Bedrock
Hi All,
Kindly help as its been 2-3 days I am not able to connect to Windchill. I am continuously getting the below error :-
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
I have cleared browser cache multiple times. Also read method server logs and fixed the INDX filegroup space issue.
Fadel
23-Emerald I
(To:Divyanshi)
from where are you not able to connect , (Creo + standalone browser) on client remote machine , on the server it self ?
first thing is try to ping the server to exclude any network issue + check what logs say MS+ Apache access logs
Fede
6 REPLIES 6
Take a look here:
Have you opened a call with PTC? This sounds like an urgent issue
Hi @Divyanshi
Without providing logs, we can't do anything to help
HelesicPetr
(To:Divyanshi)
Hi @Divyanshi
First check if the Windchill services are running also Directory Server and database.
This should be first thing what your admin should check.
PetrH
Hello DS_10805287,
You encountered unexpected behavior while using Windchill, thanks for reaching out, this is Charles from PTC Technical Support in Europe.
I will provide you assistance on this question.
Is it possible to share the corresponding MethodServer log?
Reproduce the use-case, then send me the Web Server / MethodServer / BGMS logs and pinpoint the timestamps (start/finish) and the login used.
KR,
Charles.
Fadel
23-Emerald I
(To:Divyanshi)
Fede
