Unable to find a attachment using ContentHelper
Kumar22
Hi All
Inorder to download the attachment ContentServerHelper class is used, but the method is throwing null pointer exception.
Here the The ContentServerHelper.service.findContentStream(Applicationdata) throws null pointer exception.
Please find the below code snippet for reference
QuerySpec qs = new QuerySpec(wt.doc.WTDocument.class);
SearchCondition sc = new SearchCondition(wt.doc.WTDocument.class,"master>number","=","0000078558");
qs.appendWhere(sc);
QueryResult qr = PersistenceHelper.manager.find((wt.pds.StatementSpec)qs);
while(qr.hasMoreElements())
WTDocument wtp = (WTDocument)qr.nextElement();
ObjectReference or = ObjectReference.newObjectReference(wtp);
ContentItem holder = ContentHelper.service.getPrimaryContent(or);
if (holder!=null)
ApplicationData applicationdata = (ApplicationData)holder;
try {
String fName=applicationdata.getFileName();
System.out.println(fName);
InputStream inputstream = ContentServerHelper.service.findContentStream(applicationdata);
int i = 0;
String filepath="D:\\exportfiles";
File temp=new File(filepath+File.separator+fName);
String docfile = temp.getAbsolutePath();
FileOutputStream tout = new FileOutputStream(docfile);
byte abyte0[] = new byte[2048];
while ( (i = inputstream.read(abyte0, 0, abyte0.length)) >= 0)
tout.write(abyte0, 0, i);
tout.close();
} catch (WTException e) {
// TODO Auto-generated catch block
e.printStackTrace();
satre-2
(To:Kumar22)
you can use below API to get the attachment of WTDocument.
WTDocument document=null;
QueryResult attachments = ContentHelper.service.getContentsByRole(document, ContentRoleType.SECONDARY);
while (attachments.hasMoreElements()) {
ApplicationData appData = (ApplicationData) attachments.nextElement();
// String url = ContentHelper.getDownloadURL(document, appData).toString();
Hope this helps !!
Shreyas
Kumar22
(To:satre-2)
Hi Shreyas
Using the code i am able to genarate a link which displays a sublink for downloading.The requirement to generate the link(sub link here) to download the attachment programtically.
Best Regards
Kumar
SimonHeath
(To:Kumar22)
You may need to use this API before you call the others
ContentHolder holder = ContentHelper.service.getContents(holder);
It sets some stuff up internally,
Simon
Hi Simon
As u say we have to set some stuff up internally as ContentServerHelper.service is just a interface .ContentHelper.service.getContents(holder); is not working and still throwing nullpointer.I tried ContentServerHelper.service.update method but i m not able to initialize it.
The above program throws a Warning
WARNING: The ManagerService is not initialized! This can be caused by:
1) Attempting to invoke a server only method from a remote client
2) Attempting to invoke a method on a service from the constructor or static initializer of another service
Exception in thread "main" java.lang.ExceptionInInitializerError
Is there anyway to initialize ContentServerHelper.service
Best Regards
Kumar
