Unable to open assembly (WF3.0 & PdmLink 9.1)
ptc-3139256
When trying to add a assembly to a workspace there is an issue that shows
up in the Event Manager that indicates that there is an issue with one of
the parts.
Here are the two messages that I can see
"Cannot retrieve family table neutral data"
Could not find the column with column id wt.epm.familytable.EPMFamilyTableAttribute:11697707
It is very odd, because of this issue during the "ADD" we are not able to
open any of the files in the workspace.
Robert Altman
General Dynamics Amphibious Systems
CAD Management
703.490.7533
This is an e-mail from General Dynamics Land Systems. It is for the intended recipient only and may contain confidential and privileged information. No one else may read, print, store, copy, forward or act in reliance on it or its attachments. If you are not the intended recipient, please return this message to the sender and delete the message and any attachments from your computer. Your cooperation is appreciated.
There is limited compatibility between WF3 and PDMLink 9.1. Please verify build compatibility here. If your builds are compatible, you should open a call with PTC Tech Support so they can provide debugging setting information if the issue is easily repeatable.
